GMC-IH
legopnuematic
Licensed Junk Dealer
MO
Spencer
dragstews
GMC-IH
Belleview Florida US of A
Body 1954, frame 1975
R-100
406 ci SBC
How do these install/work?
No modifications are needed to install ..
Take off the inlet fittings from the carb bowls, spring goes in first then the sintered bronze filter, there's a small paper gasket that the filter sits on making a seal between the filter and inlet fitting ..
Once installed no signs can be seen that the fuel is being filtered ..
Sintered porous bronze fuel filters offer a good balance of filtration efficiency and flow rate. They are effective at removing particles from fuel, protecting the engine from damage, and improving fuel efficiency. These filters are also known for their durability and resistance to corrosion, making them a suitable choice for various applications.
Here's a more detailed look at their performance:
  • Filtration Efficiency:
    Sintered bronze filters are designed to trap even small particles of dirt and debris, ensuring that only clean fuel reaches the engine. They can capture particles down to 1 micron in size, depending on the pore size of the filter.
  • Flow Rate:
    While effectively filtering particles, these filters are also designed to maintain a relatively good flow rate, preventing excessive pressure drop in the fuel system.
  • Durability and Resistance:
    The bronze material is known for its resistance to corrosion and high temperatures, ensuring that the filter can withstand harsh operating conditions.
  • Customization and Versatility:
    Sintered bronze filters can be customized to meet specific filtration needs and are compatible with various fuel types, including diesel, gasoline, and methanol.
  • Cost-effectiveness:
    Compared to some other filtration technologies, sintered bronze filters can be a cost-effective solution for maintaining engine health.
In summary, sintered porous bronze fuel filters are a good choice for fuel filtration due to their efficiency, durability, and relatively low cost. They provide a reliable way to protect the engine from contaminants, ensuring smooth operation and extending the engine's lifespan.
dragstews
GMC-IH
R-100
406 ci SBC
Dashboard is on it's way for a new look ..
Perhaps I should had said "A Old Look" ?
Bunch of sanding to get it looking good ..
dragstews
GMC-IH
R-100
406 ci SBC
Well how bout that ?!? ...
Was in the mode of torquing the plate on, doing three equal steps, 25-50 and final torque at 80 ft lbs .. The 25 went down as it should have, the 50 was going good too until next to the last bolt pulled the threads out of the block ...
"Great Horny Toads" and a few other assorted words was said ...
Okay, plate was taken off to do a thread repair .. I had a loose 7/16 X 14 thread kit .. But I decided to use a solid thread insert due to having 80 ft lbs on it ... Call it peace of mind ..
Didn't have that kit on hand, be here Friday ...
dragstews
GMC-IH
R-100
406 ci SBC
Finally got the inner fenders done ..
Did do a bit of work to them with welding unused holes up, sand blasting and epoxy primer ...
The engine side was top coated with bed-liner ..
Already did the underside of the hood months ago ..
Tire side has been coated with Por-15 and will be having rubberized undercoating laid on once they're back on the truck ..
That outta keep em around for another 70 years or so ..
dragstews
GMC-IH
R-100
406 ci SBC
The front panel of the inner fenders and all the sheet metal around the radiator has been coated with black epoxy primer ...
Some more work and another coat of primer and they will be ready to top coat with epoxy Hot-Rod black ... Step by step it's coming together !
dragstews
GMC-IH
R-100
406 ci SBC
That won't look to bad ..
Once all of it is back on the truck not much of it can be seen ...
But it shouldn't rust anytime soon ..
dragstews
GMC-IH
R-100
406 ci SBC
Dang Rat motor just might be grinning like a Al E Gator ..
Sitting in the engine bay .
Soon to start in on building the 871 heads ..
(Goodbye Peanut Port heads)
Somewhat of a chore finding custom made bronze valves guides with having the 11/32" I.D. ...
Did manage to get a set coming ..
jw23655
