GMC-IH
dragstews
GMC-IH
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
496's rotating assembly been balanced ..
Time for final assembly ..
Cam & bearings went in super well ..
Crank went in, got some work to do fitting the oil scraper ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Sack full of parts will be here Thursday ..
In that sack of parts is another item for oil control in the pan ...
No doubt this old truck will jump out of the hole like it was shot out of a cannon, so I'm adding a baffle to keep the oil from climbing up the back of the oil pan ...
Once it's installed lock & load time is near ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Last piece for oil control in the lower end been fitted ...
Getting really close to lock & loading the oil pan on ...
This helps to keep hot oil off the bottom of the intake ... Was going to run a air-gap intake but decided to get one that's design for the PP head ports ..
Might be a tad overkill, certainly won't hurt none ...
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Whoa !
File fitting the rings took a bit of time to do ..
One more hole to do and the oil pan is ready to go on ..
Done with dat chore ..
Back to the heads ...
Moving along ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Doing a bit of whittling on the chamber wall and seat ..
With the install of oversize valves, some work is involved to enhance the flow ...
This ^^ is the finish I'm shooting for on all 8 holes ..
Will cc the chambers to match all ..
They was at 118 cc's ..
Be a guess at the moment but I'd say they are at 121/122 cc's now that some meat has been removed ??
On to the intakes ..
Bowls are getting some big time work done to fit the oversize valves ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Boys, do I ever get a wild hair occasional !
This one is a doosy ..
In the hood a Fellow has a 48 Buick Super, past right by it on the way to work ..
Been eyeballing the rear fender running light for a year or two ..
These puppies seems to be hard to find ..
But I did find a set .. Wanting to get them in my hands for a mockup ...
If, to my eye, they don't look good, I'll sh*t can the idea ...
Not that fond of chopping holes in the fenders, but depending on how they will look on the truck .. 'I will'
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I think that will look really slick in the rear step fenders.
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Will be different, that's for dang sure ...
Speaking of different ...
Been working on other areas on the Binder ..
This might be overkill (I'm good at doing dat) installing a trans cooler, the radiator has a cooler built into the lower tank ...
Most likely it would cool the trans fluid ok ...
But to be on the safe side, I'm adding a cooler on top of the transfer case ..
It will be piggyback to the radiator's cooler ..
Since there's two ele. fans on the cooler not much need to mount it in the wind ...
Looks like a good spot, got air on both sides of the cooler ..
Working on the mount ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Here be the final design I came up with ..
Since bucket seats was installed had 3/8" bolts sticking out of the floor pan ..
Used them to mount the cooler ..
Powder coat the bracket and done with the trans cooler, but for the plumbing ..
Waiting on ordered AN-6 fittings ..
Good news about the 1948 Buick Super side marker lights ....
Found a set out in Kansas ..
Might not use them, depends on the mockup ?
jw23655
