GMC-IH
dragstews
GMC-IH
Belleview Florida US of A
Body 1954, frame 1975
R-100
406 ci SBC
You Guys think I'm building a wild and crazy truck ... !?!
Take a look at this beast ..
R-210 Travelall ...
Now that is ....
And just a wee bit overkill ...
Unless you have some very FAT friends !!
dragstews
GMC-IH
R-100
406 ci SBC
Got the remote trans cooler nailed on, working on running the lines ..
Done for the time being ...
Plumbing went well, only thing left to do is ...
That will come later on ...
(Dear Santa)
dragstews
GMC-IH
R-100
406 ci SBC
Motor oil cooler mounts are now welded on ..
The cooler has the same mounts for bolts on the bottom side ..
Was going to come off the frame rails with steel straps to put them to use ..
But don't see a need cause the two top mounts has it nailed on really good ..
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
It'll rattle that cooler to and fro eventually causing it to fail. Add the lower mounts.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Okay ...
As much as you build stuff to really be solid, leaving the oil cooler loose on the bottom doesn't jive with anything else you've done on this truck
dragstews
GMC-IH
R-100
406 ci SBC
Right-On ...
The cooler has no shake whatsoever bolted to the top mounts ...
Thought that adding mounts to the bottom would be overkill .. ??
Glad you jumped in with your comment ...
It got me off my lazy ass ! ... Lol
Thanks ..
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Right-On ...
Thanks ..
Just the right amount of kill by adding the lower mounts
dragstews
GMC-IH
R-100
406 ci SBC
Old boneyard in Northern Ca.
They said they had a hundred acres of cars ...
Bet I made 200 calls over the last 3 weeks ...
And then ....
(Ya know Guys, I'm beginning to think I might have a few screws loose ??)
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Guess what I found ?
Rough as a freaken corncob, but the picking was mighty slim !
46-48 Buick IIRC.....I have a pair of those that Dad bought at a swap meet decades ago, gonna use em as side markers on my old truck project.
dragstews
GMC-IH
R-100
406 ci SBC
Right-On ...
Thanks ..
Just about done with the lower oil cooler mounts ..
A little more welding and dressing down the welds, some rattle can paint ..
Should hang tough till I run it up on a stump !! :eek:
This is what I came up with ..
Could have done a better job dressing down the weld if I spent more time on it ... But, it's under the truck and won't be seen ...
I'm calling it 'Good Enough' !
Nborden88
