Gear Ratio! Is this normal?
paulrowe
Ontario, Canada
I have a 1979 K10 with a 350 and TH350. It has a np203 transfer case. The truck has always been a bit of a dog starting off and lately it's been bothering me. I want to tow a #5000 trailer with it this summer so I started looking into it tonight. I jacked the rear and spun the tire with one tire blocked and it appears I have a 2.23 gearing in this truck. Is this normal? Would the factory make a truck with this Gear? It originally came with a 400 motor but that's long gone if that makes any difference. I'm assuming I'd be best putting a 3.73 or 4.10 gears in this thing to tow? Also I still have the factory exhaust manifolds which I'm guessing headers would help a lot. Thanks for any help and advise you guys can provide.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
No, they wouldn't make a truck with that ratio. The smallest would be 2.73, and that's no good. Are you sure it's not a 2.73? Anyways, I'd suggest 3.73's and nothing less than 3.42's. And yeah, long tube headers would liberate some power. Getting rid of the catalytic converter or getting a high flow model would help, too, if city and/or provincial emissions regulations don't prevent you from doing so. You can add power all day in many ways. It just depends on how much you want to do.
Keith Seymore
Motor City
Keith Seymore
4.3L
Check your SPID label.
If the truck was built with the base ratio there will either be no axle noted, or it will say "GQ1" - Standard axle.
If an optional axle was installed it will say the actual RPO and noun name (ie, "GU6" - 3.42, or GT4 = 3.73).
Base ratio for your truck from the factory would be 3.07:1, although it looks like a 2.76 was available optionally.
https://www.gmheritagecenter.com/do...its/Chevrolet-Trucks/1979-Chevrolet-Truck.pdf
All this assumes it hasn't been changed in the last 40 years.
K
Craig 85
Nashville, TN
454/TH-400/NP205
My '79 was the same set up as your, but a California truck. It had 3.08's.
paulrowe
Ontario, Canada
Thanks for the replies guys. I'm going to the wreckers this weekend and I'm going to remove a 14bolt SF rear end and put that in. I'll change my front gears on my corporate. Looking at 4:10s right now. I'm going to switch to a RV type cam and go headers with an H pipe. I'm thinking this should wake her up quite a bit. I'm sure a 400 or a BBC would be a better towing rig but I gotta work with what I have currently.
68post
Indianapolis
Tim
454, TBD
That will wake it up in major way. Think small when you pick a cam.
Craig 85
Nashville, TN
454/TH-400/NP205
I did axle swap on my '79. It was cheaper to switch to 3/4 running gear with 4.10 gears than re-gear the 1/2 stuff. I picked up front and rear axles for $400. The rear was a SF with a limited slip. The only issue was I went from 2000 to 3000 RPM at 65 MPH.
The only thing you may need to do after the swap is add a second proportioning valve for the rear brakes to dial them back. The 13" brakes really grab when you have to stop fast.
As already mentioned, if you are okay with 4.10 gears, that was a very common ratio in the K20 and K25 trucks with NP203. Just pull both axles and the driveshafts from a donor truck.
With the 4.10 ratio it would help if you also upgrade to 33" tires, and they should fit without a lift kit. With a 4'' lift you can usually move to 35" tires.
paulrowe
Ontario, Canada
Ok thanks guys good advise. There's an old wrecking yard around the corner from me. It's been closed for years but they have a lot of squares still in there. The neighbor knows the guy and can get me in there. I'm going to head over and see what I can come up with. Will a 14sf from a 2wd also bolt in? Hoping to find some 4wd stuff but it's a lot harder to come by around here.
paulrowe
Ontario, Canada
Oh I forgot to mention I already have 33's on my truck.
Craig 85
Nashville, TN
454/TH-400/NP205
A 2WD rear end should bolt in, the only thing I'm not sure if the parking brake cables are the same length. I had to buy new ones for my swap as someone had used a torch on them to remove the axle. You will need a hybrid u-joint at the rear axle. I also had to shorten my drive shaft due to the differential being larger in size. My rear end was out of an '82. Here the u-joints and measurements I used.
Spicer 1310-1350 Part# 5-460X or O’Reilly’s – Precision U-joint Part# 348
3.219 / 1.062 to 3.625 / 1.188
I too would consider trying to find a set of axles from a K20, not only matching gears, but the front too will also already be 8 lug to match the back. Or were you intending to have your rear 8 lug axles re drilled or replaced with 6 lug axles?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
If you can swing an 'x' pipe crossover it will be better. But, takes a good muffler guy to fit it in. 'H' is second best. It will help with reducing sound, have to give it that. And a hellofa lot easier to fit it in. Right behind TC and under the drive shaft.
After reading the original post again, I am wondering if he don't already have 3.73 or 4.10's. He says he blocked 1 wheel ..... If this is an open diff, you take turns of the pinion yoke and multiply by 2. So lets say he got just over 2 turns in an open diff. Multiply that by 2, he'd have 4.10's. Where did he get his 2.23 ratio from? If he turned 2 1/4 turns, then he has 4.56's. I'm just saying, there might be something wrong with the way he calculated this ratio. :shrug: Maybe he did do the x 2 and got just over 1.5 turns which would be 3.08's.
guillermoariast
