Garage Cleanout
CSFJ
Getting tired of tripping over these last few squarebody parts left from the last project.
First of all, I am NOT shipping anything. Don't bother to ask. All parts will be available for pick up in Davison, Michigan. 48423 zip code.
First up, a 6.2 diesel out of a m-1008 cucv. Was told when I purchased it that it had around 10k on the odometer, and was pulled for a LS swap. I have not heard this run. Engine turns over, and has been turned every 6 months or so for the 2 years or so that I've had it. I picked it up as an extra for the truck I had at the time. Engine is complete from air cleaner to oil pan, includes both alternators, and a 24v starter. Asking $500.
Also available is a new in box flywheel to put a manual trans behind this. Includes new longer bolts required for flywheel. $100
Pics and other parts listed to follow.
CSFJ
CSFJ
Tilt column out of an '87 Silverado. Has a steering wheel from an '84 cucv on it currently. $50
A833 4spd manual overdrive trans out of an '84 or '85 chevy 4x4, comes with np208 transfer case that was originally behind it. Mileage unknown. Also included is the hurst shifter and a new in box rebuild kit for trans with bearings, syncros and seals. $650
M465 4spd manual with creeper gear, '85 and up, with 32 spline output and round pattern transfercase adapter. Shifter included. Includes hydro bellhousing. $150
NP205 tranfer case '85 and up passenger side drop, round pattern adapter with 32 spline input. Needs both output yokes. $700
More to follow...
Tilt column sold.
CSFJ
700r4 out of a 1987 3/4 ton Silverado 4x4. Was beginning to get a shudder in overdrive. "K" case trans. 119,*** miles when the truck was parted out. Includes cast inspection cover, and support braces. I figure core value, $50
NP208 transfercase from the same truck as the 700r4. Worked good, no weird noises. 27 spline input. $75
Brass radiator from same truck, I think I still have paperwork from when the truck's P.O. had it replaced not long before I bought it and parted it out. Decent shape, didn't leak. $100
Radiator sold
CSFJ
Bed floor, from an eight foot fleetside bed. Good cross supports, good floor metal on the front 2/3 of floor. Rear 1/3 was covered by a plate installed by a fire department, and rotted the sheetmetal. Supports under that area are still good. At one time, I know that aftermarket steel floor panels were available to repair the bed floor. $100
EvilGenius
Metro Detroit
Darien
I'm interested in the tilt column and maybe the radiator. I could potentially pick up today.
CSFJ
350 tbi engine out of the same '87 3/4 ton 4x4. 119,*** miles ran good I think I may still have video of it running right before I pulled it, if I can find it. $250
CSFJ
CSFJ
2 sets of factory fleetside rear wheel wells. Both sets in decent shape. $20 each or $35 per set.
Metal dash panel. Excellent condition. Uncut, no drill holes from mounting CB's or other radios. When I removed this, I cut into the firewall, so as not to mess with the weld flange. $150
CSFJ
Flywheel and pressure plate. Low miles. From a 350 with the 1 piece rear main. Came out of a '90 cab and chassis truck. $75
Hydro bell housing (fits sm465), with slave cylinder and pressure line. $60
Non-tilt, manual trans steering column w/ignition key. From '89 - '91 cab and chassis truck. $75
CSFJ
700r4 pics
CSFJ
Center console from a blazer. NOTE! THIS IS FROM A VEHICLE WITH BUCKET SEATS AND WILL NOT WORK WITH A BENCH SEAT! Blue in color. Has some small screw holes in front from what I'm guessing was a CB. $20
CSFJ
Pics of dashboard
CSFJ
Hubcaps from 1987 Silverado 3/4 ton 4x4. Nice daily driver condition. Fits 16" factory steel wheels. $100
CSFJ
Pics of hydro bellhousing and manual trans steering column
mick84
