idrivea2002golf
- Feb 19, 2025
- San Diego
- Spencer
- C20
- Not sure yet.
This is a tech question but it's for a GMT 600 so doesn't quite fit the squarebody... but there aren't any good GMC Savana forums. Plus, you guys are a lot nicer than most of the other forums.
So this is a 1996 and it has the L31 5.7 with the multiport injection. The issue I'm having is the fuel pump during start up. From my understanding GM vehicles (i don't know which, but I assume all) have a short fuel pump cycle when the key is turned, to do the initial prime. Once the pressure is there and the engine starts it then hands over the fuel pump operation to the oil pressure switch. All seems easy enough. Where I'm stuck is why I'm not getting that initial prime.
When I turn the key I do not hear the pump prime. So I've checked/replaced (for good measure) the relay and the fuse, no change. The van will start if I hold the key for a bit and allow oil pressure to build. So I know the pump and the oil pressure protection circuit are working. I can kill the fuel pump by disconnecting the oil pressure sender while the engine is running, also good.
What's my next diagnostic? Thanks!
