Front inner wheel wells
Jray8
Arnold, MD
As I begin work on my 87 square body truck I thought stopping the rust might be a good place to start.
I need to replace the front inner wheel wells. Can they be replaced without removing the fender or front clip? Not exactly sure what I am in for replacing them.
Thanks
J Knight
Baytown TX
82 Chevy
350ci
I havent done it but you should be able to jack up the truck, remove the tire and drop the inner fender with no problem.
Jray8
Arnold, MD
Thanks j knight.
I guess I got this in the wrong catagory. Lol.
Moved it for ya.
The biggest problem you may have when removing them is getting the bolts loose. There might be a couple in the wheel arch area that just spin because the speed nuts are broke. If so, just grind or cut off the bolts.
carter34
