front end sag
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
Brought home my first chevy truck the other day! 83 k20 with a 350 and 4speed. There is a plow mount on it but no blade, but the front end sags quite a bit. The front springs are bent upwards. my question is on the best way to correct this. I'm going to be selling the plow and have been contemplating getting a 4" lift. so my question is new stock springs or get a lift?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Stock springs ride so much better.
The stock front springs are negative arch, so they may not be as saggy as you thought. If you want to run bigger tires, go with a lift.
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
I'm thinking i'll go with a small lift and bigger tires. the truck has 4.10 gears and really seems to beat itself up without overdrive
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
IF your gonna replace the springs anyways go ahead with a 4inch lift and some 35's. Youll be ok with the 410's unless you wanna run 80 down the interstate.
