Front drivers side turn signal. Light works but wont flash when you turn on the signal.
Huckleberry
Valley Bend WV
Donnie
K15
350ci
1978 GMC. K15. Front marker light won't flash when you put on turn signal. All other lights work correct.
rancher1913
Colorado
brian
c10, k5, k30
check ground and also check that somebody did not stick an led buld in it, they need a special flasher control
mlsceo
Kingsburg California
Manuel
Probably just a bad ground. When mine does that I give the fender a tap with my fist and it goes right back to flashing.
beast6303
