Front Brake Rotor
bigge31566
GA
Ervin
On a 1983 C10 front rotor and hub can you separate the hub from the rotor, or is it all one piece, I see some rotors don't come with the hub, basically I want to switch to drill and slotted
I thought they were one piece? :shrug:
bigge31566
GA
Ervin
I looked this morning and I don't nowhere for it to separate either, but they are selling rotors without the hub
Where are you looking at?
bigge31566
GA
Ervin
R1 Concepts on ebay, they call it there Eline
bigge31566
GA
Ervin
2 FRONT] ELINE "DRILLED & SLOTTED" Performance Brake Rotors
No......stock front rotors are one piece. There are companies out there that make a two piece rotor and hub assembly, like Baer, EBC, and a couple others, but you have to buy them as a kit.
highdesertrange
kalifornia
mike
k30
2 wd 1 piece. 4 wd 2piece. highdesertranger
Could have been generic photos used in the ad too. Unless they expect you to have your stock rotors turned down into "hubs" and slide their rotors onto your new "hubs". You would then need longer wheel studs too if that were the case.
bigge31566
GA
Ervin
Received rotors the other day and they had the hubs on
I see a lot of that lately with the generic photos :shitsweak:
Sent from my iPod touch 4th Gen using Tapatalk
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I have seen them listed online for the V10 (4x4) that give you the option for a one piece assembly, just the rotor by itself or just the hub by itself. I have seen a similar setup on my Datsun, but I don't see any bolts holding the two parts together like on the Z. Maybe the two are held together by the wheel studs? If I drove those out do you think the hub would come apart?
Unfortunately I'm working odd jobs under the table at the moment and I can really only barely even afford the rotors without the hubs, but I don't see any reason I can't reuse my hubs to begin with. Not like the bearings are shot and have ruined the inside of it or anything
85Shortsquare
