- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
You can tell the gear ratio when you pull the cover to change the fluid. It will have a stamping on the side of the ring gear that says something like 10 34 or 10 41. If you divide the big number by the small number you will get your gear ratio. You can also tell by lifting up the axle and turn the driveshaft while counting the number of times it takes to turn one wheel a full rotation. If its 3.42 gears it should take ~3 1/2 turns to make the tire do one rotation.It’s an 87 front axle, 3.42 gears supposedly is what the truck came with factory. I’ve counted the bolts before I bet it’s a 10 bolt. I don’t know 100% if the front and rear gear ratios are the same tho… the rear end has been swapped before(internals not the whole axle)
