Fox shocks
Paul Gervais
Litchfield ME
K10 Scottsdale
5.3 Spooly Boy
I’ve been googling I’m going nuts
I want some shiny fox reservoir shocks. There’s no direct fitment available and there are one million different universal ones.
does anyone have pn for front and rear with 6” lift?
OzarkRunner
SW MO
Daniel
GMC V1500
I think you'll want 985-24-052 for the front and 985-24-054 for the rear. The front has a 10" travel and rear is a 12" travel. Both of these part numbers are with remote reservoir and eyelet / eyelet design. The travel, compressed, and extended dimensions match up with Bilsteins I can find on ORD's website, but please check me.
Edit - I do not know what the eyelet sleeve dims are, or should be, but hopefully those part numbers get you started.
Booyakashaw
Canada
Del
K2500
I would be interested in these also.. little on the pricey side, wonder how they would ride on the old square body.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Don't overlook these...
Doetsch Tech... family run, good product, good prices, good service.
Below are the one's I have bought before. They will valve them for your truck and use. And you can rebuild them at home. They will
supply the parts needed. While in in there, you can change the settings too. You can buy with the res or buy it later and add it on.
https://www.shocksandsuspension.com/5.asp
mick84
