FORD RAKE ?
jjewett444
New York
jim
I know you guys are probably gonna hate me starting a thread on a gm forum that says ford lol but my question is, what is the best way I can lift my rear end of truck up a little to give it that old f100 "rake" like they all had. ever sonce I did new ball joints springs and shocks in front it makes it look too level. I know its probably better that way but I would like to have the rear sit just a tad higher that the front. btw my truck is 1984 c10 short bed if that helps any.. thanks in advance fellas
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Add-a-leaf, a small block, but both would require new U-bolts. Ford did that because they couldn't make it sit level and still haul. Lol so they tossed in a little suspension Viagra and made them sit goofy. Lol most people get a leveling kit to raise the front end to level it out.
jjewett444
New York
jim
ok so its either add a leaf or blocks> or both? know anyone who makes a kit? idk I just happen to like the raked look and since I redid most of my front suspension and need to do rear shocks I might as well go ahead with the rear
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
How high are you looking to go? 2"?
jjewett444
New York
jim
I checked your link but none for c10, I think I found some on rockauto. Yeah 2 inches is probably what I would lift it. Also what shock height should I use for it? And will my pinion and u joint angle be off? Or is this add a leaf just a soimple bolt on thing?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It will work on a C10 as well. It will change your pinion angle a little. Is your truck A long or short bed? Shocks probably C20 would be the proper length. Bolt in yes simple pretty much just have to be careful when disassembling the leaf pack. C clamps are your friends when doing this.
jjewett444
New York
jim
Truck is shortbed. I do not want to make any modifications in order to keep everything in the right angle or whatever I'm looking for just a quick fix. So if I got helper springs and u bolt kit and shocks is that all I need?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Pretty much. Regardless of how you do it blocks or spring it's gonna change the pinion angle, but probably not enough to hurt anything.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I wasn't sure what was meant here by "rake," and when you said this, stock photos of 1973-79 F100s just came flying in my brain. Lol
CSFJ
If you replaced the front springs, why not replace the rears with new factory ones too? They probably have a bit of sag to them like the fronts did. Or are you after more rake than what gm designed originally?
jjewett444
New York
jim
There are not many springs on rear, so I assume it wasn't a HD Silverado new lol. But I am looking for maybe 2 in lift. Jiust so rear sits slightly higher that front. Im not a fan of my "gasser" lol
CSFJ
Just wondering. These trucks had a little rake from factory. And the last car i had, when it came time to replace some suspension, I did the same thing. When it came time for new front struts, I fired in a set of quick struts, instead of swapping the coils over like I did in the rear. Ended up with the same gasser look. On a little front wheel drive no less. Lol
dhaayer
