Factory Air Cleaner Housing
SquareRoot
I'm wanting to use the OEM housing on my 85. Couple questions come to mind.
1. Will a standard 14" aftermarket filter fit?
2. Will the housing clear my HEI?
I'm thinking I can find something in the junkyard but I know of a few 88+ burbs to pick from, but they probably got this and a different configuration? I'm not opposed to modifying/fabricating things to work.
The goal is to make it look more factory and plumb the snorkel to the original birdcage on the core support.
I'm also running an Edelbrock 1406.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
You need to make sure the base has this dimple at the rear for the HEI. I don't think a 14" air filter fits inside the OEM housing. I know they do in a 6.2 diesel air filter base. I would look for the tall air cleaner lid as it's 2" taller than the one you pictured.
Also starting in '87 the snorkel portion of the air cleaner based for EFI (picture #3). I don't know if the fresh air tube is available for those models.
SquareRoot
I appreciate the info. I wished I'd thought about this a few years ago when I had free reign to pillage a fleet of cucv's. I would have taken way more than the axles.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Factory truck housings will only fit a 12 inch air cleaner. However, if you look at the bottom of the pile here, the air cleaner on the bottom came off of a 71' Olds cutlass, and it will accommodate a 14 inch air cleaner, and the one in the middle is off of a 77 ish Pontiac and also will fit a 14 inch air cleaner. If they won't clear a HEI cap you can find a spacer from a 71-72 ish pickup that goes in between the carb and the air cleaner
Here is one of those spacers next to the thermostat housing.
75gmck25
Northern Virginia
Bruce
When I was using an Edelbrock 1406 my stock air cleaner would not sit evenly and clear the fuel fitting. Edelbrock sells a banjo fuel fitting conversion that might provide the fuel fitting clearance, but then you have to work around the hieght of the choke housing
The TBI spacer shown in the picture above will give you the clearance, but I found that it "clocked" the air cleaner differently and the snorkel did not point in the right direction. I used the Edelbrock plastic spacer for a while, and finally just decided to buy the Edelbrock air cleaner that fit the 1406.
If you decide to try an Edelbrock air cleaner, make sure you get one that clears the 1406 fittings. Unless they have changed them, the Edelbrock 14" air cleaner they stock at Advance Auto Parts will have the same fuel fitting clearance issues you have with the stock air cleaner.
Bruce
Dons79C10
