exhuast leaks
86chevyk20
Buffalo
Liam
I just installed my header back kit from summit and I got some leaks at the pipes that slide over the collecter. The guy who expanded them made them a weeee to big. He clamps are as tight as I can get them.
What should my fix be. Weld the leaks? Or putty?
The putty will just crack and blow out. You can put on a second clamp, but turn it 90 degrees compared to the other one. If that doesn't completely seal it up, miles of soot and corrosion will, lol.
I'd weld it myself.
Where did you put that flute again??
So that's what the band director meant when he said 89S had a ****** flute !!! Sure glad he didn't play the trombone !!!
He'd have a muddy trombone (or given someone a muddy trombone) if he did I guess.... :eek:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I prefer a fully welded exhaust system myself, but that's just me.
Yep me too. With exception of I have headers, I want bolt on collectors so I can remove the pipes for the track. I usally go with straight pipe to muffler, then a turn down just before the rear axle. But, I have to admit, that band clamp looks like it would do a hell of a job, and that would be great for anyone who has to run a cat for smog inspection, then can take the clamps off and put their straight pipe back in after inspection.
... and that would be great for anyone who has to run a cat for smog inspection, then can take the clamps off and put their straight pipe back in after inspection.
:hmm:
:evillol:
Not worth it, you wont notice a difference, except for the exhaust smell....which you know of ll to well anyways.
I still want to get a pass side exit on this thing. or just run it straight out the back or something.
imyourhuckberry
