Exhaust Exit
bigge31566
GA
Ervin
Where gives you the best sound for dual exhaust exit to the sides or the rear
1984K10
Baytown, Tx
Cristian
5.7 (350CID)
I don't think the place it exits actually makes much of a difference in the sound it makes. That really depends on the exhaust system itself such as the cats (I've heard hi-flo makes a different sound from "regular") and muffler. If anything, having it on the sides will make it SEEM louder while you're in the cab but only because it's closer to you.
Rear is my opinion. I'm itching for some dual chrome tipped rumblers under Silvy's fat ass.
Driver4r
Nebraska
Trevor
k10,c20
Rear is nicer for trips. the drone is farthest behind you. Ive thought about changing mine to the sides, but idk if i will. But my vote goes to rear exit.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
I think exit location depends on how much you drive it and if you want to hear anything in the cab besides exhaust noise.
Loud exhaust that sounds good for 10 minutes can give you a headache after an hour of driving. Also, do you want to be able to hear the radio without having it full blast?
I love a great sounding engine but as I get older I don't have as much tolerance to hear it full time. At the dragstrip I'm all for loud but if I have to drive any distance just a nice rumble will do for me.
Moderator
I think rear usually sounds best because you can hear both pipes at the same time, no matter where you are standing, or driving. If you are cruising down the highway at speed with the window down, a side exit pointing at a concrete barrier can be annoying. But if the exhaust is quiet, none of this matters.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Well mine dumps straight out of a pair of Flowmasters right before the axle. Rumbles like crazy but I like it that way lol.
I can't find **** for a good cat back dual exhaust. Maybe a GMT400 Burb sytem will work?
Moderator
Their y-pipe exits on the passenger side.
gpmorgan
Tupelo Ms.
greg
Here's a vid of my truck in the cab. I have 2- 40 series Flowmasters that exit right before the rear axle. You can tell more about it with headphones on.
http://www.youtube.com/watch?v=0UswaVHqvX8
There are a couple more vids on the same page. 92 Silverado 355
I wanted to add that both my pipes run on the right side and the exhaust turn downs are approx 1 foot apart.
Driver4r
Nebraska
Trevor
k10,c20
89, flip the y to the other side???? im sure you could jerry-rig it up somehow
bigge31566
GA
Ervin
what size exhaust are you using
farmerchris
southeast kansas
chris
if you pull a trailer,rear exit sucks to be hooking it up with the truck running :)
crowe-t
