- Apr 11, 2017
- kansas
- Rick
- c20
Robyn I feel your pain and I think your best option. Now is tune it for how it runs best 90% of the time and have the ability to pull a few degrees on the other 10% . Maybe at some point you will figure out which circumstances create your ping and be able to control it better. Things to think about thermo vacuum switches,hobb switches,throttle postion switches, Different hg. advance cannisters. I don't want to confuse anyone and this and it is just one example. Say the truck only pings from 200 degrees at and up so a thermo vacuum switch that provides vacuum to a hobbs switch at temperatures 195 and above creates the ground to pull timing. That's just 1 example. Another example of something that might help,a water injection system maybe both. I did make a very crude water injection system once using a metal windshield washer squirter.i drilled a hole in the air cleaner top put the end of the squirter through the hole mounted it to the top and aimed it so it hit above the venturi hitting the side of the airhorn so the water wasn't shooting straight through the throttle plates it was hitting the wall and breaking up going in as a mist. Fed it water with a washer pump
