Engine runs poorly spontaneously?
Rusty Nail
Cowboy of both Time and Space
your first name only .
350sbc L98
matter of fact - there is a test for that...u can measure the resistance and perform a "sweep" while you make sure it moves smoothly with no gaps.
or something. :shrug:
motionz
Netherlands EU
M
BIG10
350ci
By now, everything from the battery to the ignition has been measured and/or replaced:
- +12V cable from starter motor to fuse box
- from fuse box to starter switch
- from starter switch to neutral switch and distribution cap
- from neutral switch to starter motor solenoid
- new distribution cap + rotor + HEI module + ignition coil + spark plugs + spark plug wires
Unfortunately, this had no effect..
While measuring the ignition timing, I manually pull the throttle on the carburetor and felt around for leaks with my fingers. Exactly behind the heatpipe choke unit, I felt a strong suction effect. The suction spot was not visible! but I removed the Impco set and carburetor, and this is what came to light! see pics
I had a spare gasket but it's a different model see pic. can I use this gasket? a small section between the throttle valves is then not covered
@75gmck25 the intake manifold is original cast iron
75gmck25
Northern Virginia
Bruce
You definitely found the source of a big vacuum leak!
There are multiple gasket configurations for a Quadrajet, and I find it’s difficult to know for sure exactly what coverage of the base is critical. For now you might just try the other gasket and see if it runs better.
The typical solution is to look up the carb number for the recommended gasket. It might take a while for shipping from the US, but at least the part is really light.
Rusty Nail
350sbc L98
dude.
you're going to have so mush POWA!
NLD79K10
Netherlands
Lars
@motionz I think that gasket under your Q-jet is the FelPro 1908. Pretty sure I saw that AJ Speedshop in the Netherlands had that gasket in their webshop when I last looked around for one.
motionz
Netherlands EU
M
BIG10
350ci
Yes, finally a major find that is most likely the cause!
Although I still find the irregular spark plug spark suspicious.
But first, replace the base gasket; it is a Quadrajet Rochester model number: 17058508.
I think it is the M4MC carburetor type with a hot air choke.
I ordered a gasket set from my new supplier in the Netherlands (Rockauto no longer supplies to the Netherlands), see pic.
NLD79K10
Netherlands
Lars
Just ordered a bunch of stuff from Rockauto myself with no problems getting them supplied to the Netherlands. It's just that with the economic sanctions on Russia due to their invasion of Ukraine, imports of parts from manufacturers that do not provide certification that they were not manufactured using Russian steel into the EU and UK are banned. This can limit your choice of brands for certain items. For example for my K10 I can't order Bosch or Dynamic Friction brake pads from Rockauto but I can order Raybestos ones. It's a bit annoying at times but you can still get stuff shipped in, provided the manufacturer has submitted their paperwork.
motionz
Netherlands EU
M
BIG10
350ci
strange i get the message when i checked out that a "new European packaging law is active (PPWR)" ? Maybe it has changed in the meantime you never know..
Rusty Nail
350sbc L98
or something.
you are likely building on a bad foundation.
I want to "double down" on the pick-up coil.
motionz
Netherlands EU
M
BIG10
350ci
The piece who was sucked out of the carburetor base gasket is the first major fault I’ve found!
Yesterday, I cleaned the carburetor using cleaner and a brush, and also adjusted the spring for the secondary throttle plates.
After reassembling everything with the new gasket, the engine fired up quite quickly and runs beautifully.
I immediately tested the choke operation, and it seems to be working well; I also measured the timing and RPM with and without the choke, see the photos.
The timing appears very advanced 18 degrees, even though it was previously set to 10–12 degrees? although the engine runs very well
NLD79K10
Netherlands
Lars
Nothing wrong with a bit of additional advance with modern fuels, I have mine set at 16 degrees initial to compensate for the slower burn of E10 95RON.
Did you check the advance with vacuum hose disconnected and the port plugged on the carb?
I also like the engine to idle a bit faster than yours is showing to ensure it won't stall, mine is running around 550RPM fully warmed up with the TH350 in drive which is a little faster than stock but pulls away from a stop a little nicer when hauling a trailer, you can check what your setting should be on the emissions sticker on the radiator support. Your fast idle seems to be on the low side as well, I'd personally aim for around 1100RPM on a cold engine with the choke fully engaged.
motionz
Netherlands EU
M
BIG10
350ci
Sorry for the late reaction, was on Holliday. I'll start by performing the check without disconnecting the vacuum advance hose I forgot to disconnect it... I drive mainly on LPG, so the timing can be set a bit more advanced. I'll also bump up the idle speed slightly while in 'Drive' with the handbrake on.
motionz
Netherlands EU
M
BIG10
350ci
The ignition is set to 4° without vacuum advance, and the engine runs very smoothly. With vacuum advance, another 14° is added, making a total of 18°. I do notice, however, that it is less responsive when I step on the throttle. Is this the correct setting for LPG?
The engine speed is set to 740 rpm in Neutral; in Drive, it drops to 550 rpm warmed up
Any specs written would have been for a new engine with a new timing chain,good ring seal,etc.etc. and probably none published for lpg.Id bump the timing 2°degrees at a time until I found where the engine quit responding to advancing the timing. Then go back to the lowest setting where the engine ran best. That would be MBT ( minimum best timing) that will get you best fuel milage and coolest running engine. I usually check it by dead stop accelerate past a land mark 4-600 feet away note mpg as you past the land mark. When the MPH quits increasing go back to lowest timing that had best MPH.
NLD79K10
Netherlands
Lars
4 degrees BTDC is quite retarded timing in my experience, especially on LPG. I'd start with giving 4-8 degrees more advance to start off with and then advance it 2 degrees a time on successive runs to find the best timing for your setup as @Ricko1966 recommends. You may want to verify a run or two on gasoline after setting timing on LPG to make sure the engine isn't pinging on Euro 95, LPG has a significantly higher octane number than 95 does.
Judge
