- Sep 3, 2024
- Nebraska
- Goober
- C15
Smoke test, thorough visual inspection of all vacuum related hoses, gaskets, spraying carb cleaner around areas associated with vacuum etc.Have done a vacuum measurement on PCV port value = steady 16inHg at high rpm, see picture. Engine runs very poorly and make sucking noise when I let it run stationary, I make movie but can't attached it? Vacuum value is very low 4inHg
Some cases a leak will be obvious by the "hissing" sound.
How To Smoke Test For Vacuum Leaks: A Step-by-Step Guide
Learn how to smoke test for vacuum leaks with our comprehensive guide. Find and fix engine problems with this essential diagnostic technique. Get step-by-step instructions and safety tips.
