Engine Problems
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
I have an 87 Sierra with a 350 tbi and while driving the truck it starts to sputter and bog down just recently it died and i had to wait 30 mins before it would even fire again
just replaced spark plugs
wires cap and rotor a year old:help::help::help::help:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Vapor lock? Low fuel pressure? Stopped up fuel filter?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
i never thought of vapor lock i know i changed the fuel fiter about 6 months ago
also the check engine light came on a couple of times
crazy4offroad
Curt
K-10
350/SM465/NP205
If it has OBD I pull the codes, let's see what ya got. Vapor lock could judt be the gas cap isnt venting, and your charcoal canister is plugged not letting the gas tank vent right. Next time take the cap off and put it back on and see if it fires right up.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
okay just checked to see if there where any codes and the only code was 12 and that means the computer is working right and the truck fired right up and ran good
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Sputtering screams fuel filter.
No vapor lock, fuel moves too quickly through the system.
When you turn your key to the on position, does the fuel pump prime for 2 seconds, or 15 seconds?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
the fuel pump primes for 15 seconds
could it also be electronic spark control modual
or the Ignition control module which was replaced last year
Jims86
Patterson,Ca
5.7 TBI
Could also be the coil. Have you confirmed no spark when this happens?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
no but the coil was replaced last year but i know that doesnt mean it cant go bad again
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
just today the check engine light came on and through code 42
i have already replaced the ignition control module a year ago and checked the wires that lead to it and they looked good
Jims86
Patterson,Ca
5.7 TBI
check the timing connector, and make sure its snapped tight.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
where is the timming connection located not sure if its under dash my wiring diagrams are hard to follow
Jims86
Patterson,Ca
5.7 TBI
should be near the brake booster. its a single plug with a tan wire.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
the only wire i found was tan w/black stripe but ill check tomorrow
also after i disconnected the battery for a few mins and reconnected it the truck ran fine
Jims86
Patterson,Ca
5.7 TBI
Thats the wire. When you disconnected the battery, did youlet it get to operating temp? If not, it will run fine on factory settings from the calpack, until it gets into closed loop mode, where it uses the readings from the sensors.
Shak379
