engine lag when takeing off
chevyfox
mo
isaac
v10
Whenever I take off it takes a sec for it to get going and being it I don't know much about this stuff I was hoping you guys could let me know what you think it is!
rich weyand
Bloomington Indiana
Rich
Two candidates:
1) not enough shot from the accelerator pump. When you open the throttle plate, air rushes in, and the gas can't keep up, so the engine goes way lean. So it could be lean sag. Carburetors include an accelerator pump that squirts extra raw gas into the bores when you step on the accelerator, to compensate until the fuel flow catches up. If the shot is set too low, you get lean sag.
2) having the vacuum advance on ported (or timed) vacuum, instead of manifold vacuum. Manifold vacuum sets the distributor for the current cylinder pressure at ignition in the engine to get the timing right for that cylinder pressure. Timed vacuum was introduced for emissions control, and dumps the vacuum advance at idle -- sort of "since you aren't using the engine for horsepower right now, I am going to change the tune for low emissions". When you get on it, it takes a fraction of a second for the vacuum advance to retime the distributor to what the engine actually needs to produce power.
So first move the vacuum advance to the manifold vacuum port on the carburetor, that's easy. Then, if that doesn't clear it up completely, see what your accelerator pump is set to and increase the setting.
Tell us what carb you have and we can help with more exact instructions.
350runner
tx
Ceasar
I like the ideas rich has. I kinda was thinking torque converter or trans issue as you say it takes a while to get it going. Do you mean it is just slow or it revs up for a sec then goes?
chevyfox
mo
isaac
v10
Its a throttle body and it just feels like its taking an extra second to get going it doesn't rev
rich weyand
Bloomington Indiana
Rich
Oops. Didn't check the year. Yup, 1987 is all computerized.
Sorry. I don't have any experience with those, so have no help, I'm afraid.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Check your EGR function and TPS. There should be a guide out there on troubleshooting GM EGR systems.
I have collected a lot of good info and stuck it in the EGR thread. I agree pointing that out as a culprit.
Disconnect the EGR valve and see of it stops. Of not, it's something else.
chevyfox
mo
isaac
v10
Alright where is the egg valve?
chevyfox
mo
isaac
v10
Egr lol
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Passenger side at the rear of the intake manifold.
Look at your vacuum diagram.
twzorek
