Dual Thrush or Dual Cherry Bombs?
BigAl285
Wisconsin
Allan
383 S.B.C
I've had purple hornies, cherry bombs. They all sounded similar. I had a oarnge pair can't remember the brand but those where junk in a year but this was many years ago too. I like the flowmaster series 40, thats what I'm running now, it has a big rumble / wraps out good too but I'm have some horsepower goin through them
Driver4r
Nebraska
Trevor
k10,c20
When i start working on the monte again, im gonna get a set of the header back purple hornys.
chubble
Eastern, NC
Custom Deluxe K10
I should have mentioned, those $10 glasspacks were in the late 90's, those stores closed in '00 or '01. I didn't realize it had been that long.
Oh :bawl: If I thought I could get a pair for that cheap I would have been stoked...more money for other little things that I'd like to order (marker lenses, dome light cover and LED's for the gauge cluster)
I was leaning heavily towards the purple hornies because they bolt straight to the headers... but crawled underneath my truck and remembered that stock headers don't have that mounting bracket. I think I'm going to go for a pair of Thrush. It looks like I can steal a pair off Amazon for about 40-50 shipped, That should leave me with enough $$$ to get an Edelbrock Aircleaner, and maybe some polished exhaust tips or Edelbrock Valve Covers.
chubble
Eastern, NC
Custom Deluxe K10
Is it still generally accepted notion that the longer the glasspack the lower the tone?
bigcountryguy19
Sealy texas
josh
6.2 diesel
Usually I have found the longer they are the quieter they are
chubble
Eastern, NC
Custom Deluxe K10
i imagine that without cats any of them would still be pretty loud. i guess I'll just go for the model that is medium length and a 2 inch through pipe since my inlets and outlets are 2 1/4, and hope for a good sound
notverrysmart
washington
EJ
suburban
The bigger the diameter the deeper the sound, the longer the muffler the quieter the tone. 2 1/4 should be fairly deep and you could always go to a 3 or 4 inch tip to get it a little deeper.
Christian Nelson
Wisconsin
Christian
K15
Longer they are, the less snaple crackle you get, also the closer you place them to your manifold/header the more the snapp crackle pop will be pronounced. You place the packs further back, you will have more rumble, less crackle.
Driver4r
Nebraska
Trevor
k10,c20
I have 2" pipe with the glasspacks just under the cab/bed gap, and it cackles Pretty good :) .
Moderator Administrator
Most glasspacks (called cherry bombs around here, no matter what the brand as long as they are red) are all about the same as far as durability and sound. Even the $10 ones they used to sell at Quality Farm & Fleet. I've never had a single one rust out. The welded type mufflers do rust out, even the Flowmaster brand. Except my Hooker Aerochambers, they seem to be holding up as well as any glasspack.
Some will refer to Glasspacks as "Cherry Bombs", Just like they call all Arc Joint Pliers - "Channelocks", and all String Trimmers - "Weed Eaters", But doesn't mean it's right. :insane: Just Sayin...
I never have liked glasspacks. Quiet or Loud. They're a great way to "Cheap Out" and get something legal so you can drive it, but past that, I'd go with a muffler. Take your pick, Thrush, Dynaflow, Magnaflow, Flowmaster, whatever you like.
In the race days, a couple guys did have the glasspacks with the Header collector flange on it, just to bolt to the header and be street legal. But 6 bolts later, it was uncorked and racing w open headers. Didn't even need to use hangers for them.
MrMarty51
Eastern Montana
Martin
Straight pipes, inch and seven eights, straight out past the rear bumper.
You wont hear it much, but, watch out behind. LOLOLOL
1 & 7/8ths gives it that nice crisp "Rap".
bajadiver
