Dual Tank Rocker Switch
Doppleganger
OH-MI: Just like it sounds
Any you guys swap out the newer 1987 style rocker switch when you went LS, EFI, etc? I found that on of the blade terminals on the 87 switch is different so it wont fit in the pre-87 dash connector. I have seen a "hot rod hack" mentioned where they grind off a nub on one of the terminals to allow the switch to fit.
Do I need to procure an 87 connector? What did you do with yours?
THX
lukes78
