Drum to disc
Brandon777
US
Brandon
Is there a 8 lug conversion kit from drum to disc brakes for a 1978 k25? I've really only seen 5 and 6 lug conversion kits.
Thanks
Carb'ed Vortec 350
Might be easier to swap 8 lug axles in instead.
If it was a C20 you just need the front control arms and spindles and other brake related hardware.
MadOgre
NA
NA
NA
NA
NA
You have drum brakes on the front! ?
There are disc brake conversion kits for a 14 bolt FF axle. Semi float too
Brandon777
US
Brandon
No, I have disc in front and drum in the back, I'm looking for a conversion kit for drum to disc, and I need a 8x6.5 rotor and most kits are 5 or 6 lug instead of 8
Carb'ed Vortec 350
I was thinking it was odd for a 78 to have drum on the front. When you didn't specify my brain just went to the front brakes because of the conversion I'm getting ready to do. :shrug: :cheers:
Brandon777
US
Brandon
What conversion are you doing in the front?
Carb'ed Vortec 350
It's converting my 65 3/4 ton fleetside from drum to disc. Just need a couple more parts and some time to do it.
Brandon777
US
Brandon
Nice, I forgot the older trucks have drums all around
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
what axle do you have 14 bolt full floater or semi floater
diyx4x.com has a awesome disc brake bracket I have used it many times. it uses a front 3/4 ton rotor and caliper
77rig
