Driver Bed Side Sagging???
Ozie P
FL
Ozie
In my 84 K10 SWB, it’s has about an 1.5” lower height to the driver side of the bed. It has a 6” Skyjacker Suspension lift on it but the shocks have definitely had their share of life. I made the assumption of it being spring sag in on the driver side so I swapped the rear springs out for some stock ones. However, nothing changed. Any ideas? I took several measurements from the frame to the ground and the entire length of the frame the driver side is lower. I need help ASAP.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome::welcome:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Looks like maybe the frame is twisted. It’s a good looking truck though.
Ozie P
FL
Ozie
If you pick up on the corner of the bumper ever so slightly it levels out and looks fine. Still twisted frame?
EightyEight
Phoenix Arizona
Tony
V30
Did you inspect the spring mounts? Are they straight? Measure the spread between each of the spring mounts see if they're the same? Looks like my friends 450 lb sister is sitting in the driver's seat....o_O
Ozie P
FL
Ozie
Springs mount are straight. New springs went in easy. I’ll take a quick measure and see the distance. I’m only 5’11 185 so people are gonna think I’m huge until I get out...
Ozie P
FL
Ozie
Driver side (sagging side) is about 3/4 inch longer on spread from bolt to bolt. Could this be in the shackle?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Check your cross member attachment points
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
For spring shackles?
The ones that hold the frame rails together. And go over the frame with a fine tooth comb so to speak.
Ozie P
FL
Ozie
I’ve gone over them a hundred times looking for cracks. Only thing I’ve found is where the rear shock mount broke and someone welded back ever so slightly. Could the difference in spring spread be a cause?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I know this may sound dumb and a lot of work but swap springs side to side and see if your lean goes the other way.
wootensan
