Dorman leaf spring shackle
ThreeLRanch
Cleburne TX
Kenneth
I bought these to replace when I do my springs and the only one it showed was one and was for 3” springs. I didn’t measure the springs because I thought they were around 3” but now idk if these will work or not. I’m sure they will squeeze down but is this right ?
ali_c20
Austria
Alexander
C20, K5
A little squeeze is ok but not that amount. You can add a washer left and right to fill the gap and have the spring centered. The hole in the washer has to be the same diameter as the hole in the shackle / bolt.
ThreeLRanch
Cleburne TX
Kenneth
That is what I was thinking , thanks for the replay .
ThreeLRanch
Cleburne TX
Kenneth
I tires to put a washer on each side and only one will actually fit so the gap isn't as much as I thought , I had actually cut some 1/4 spacer out on my laser but I guess I will not need them now .
ThreeLRanch
Cleburne TX
Kenneth
Got the 2” tuff country lift on , 33x12.5 on stock rallies.Took it in a short drive and I sure hope the springs settle in and get a little softer because it seems pretty stiff still.After I get the rear driver break line replaced I’ll take it for a longer drive , I sat the spring up on the axle and apparently the break line decided it need to be replaced because it started leaking . I guess some how I hit it with the spring.
xm20k
Girard, Ohio
Think they are supposed to be 2.5" but not sure because I see both listed, but if they fit in the brackets and just the spring end was a bit loose a spacer/washers and few uga dugas should be fine. You did wait to set it on the ground before fully tightening everything? Bushings can bind a bit if tightened while everything is drooped and then everything will be in a bit of a bind once it has weight on it.
Zelph
Nevada
Aftermarket springs are typically 2.5” wide, while factory springs were 3”.
Having play in the bushing will cause all sorts of issues, including wandering all over the road.
Cyrillious
Toronto
Cyril
K10 Suburban
I added washers to mine and they are the same diameter as the pin hole. I have mine more to the centre just to keep it away from possibility of rubbing on the tires. Feels fine on the road.
xm20k
Girard, Ohio
Not sure about that because my stock BIG TEN springs were 2.5" wide because I measured them to make sure when I got the lighter 4 leaf springs, I wouldn't have an issue.
ThreeLRanch
Cleburne TX
Kenneth
Yes I loaded the suspension before tightening everything up .
ThreeLRanch
Cleburne TX
Kenneth
I was only able to put one washer in it so I figured that it would tighten down if that is all that it was . It looks good now with no gap in it .
jw23655
