Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
I learned that quality control in this era sucks! No two doors are the same. If you're going to swap doors, don't bother marking anything as it will just take lots of time and effort (beer) to get them close to being right.
This has been my fear / suspicion. My drivers door had a slight 'push' just front of the door handle. I dont think it could have been fixed - was like a stretch in the steel that would pop in-out. I took one of those mending panels you get at a hardware store - 5x8 piece of steel with like 20 holes in it - and some 3M panel adhesive. Using some magnets from an old hard drive on the outside, I glued it inside the door to thicken and reinforce the stretched area. Worked very well. You can still get it to flex, but its solid now - is much stronger and straight like it originally was. So I think my original door is ok to keep, but they still need to come off to repaint / color change. I dread that.
