Door lock relay whereabouts.
john ward
UK
john
77-83 and inbetween
Hi all looking for the door lock relay on 83 c10 is it under dash or hood ? anyone got a pic.
gmachinz
Harnessworx Inc
Iowa
Jabin
Yeah it’s fun to get to lol
john ward
UK
john
77-83 and inbetween
Thanks guys..
Terry Wilkerson
Kansas
Terry
GMC 1500
So is the white connection the door lock relay from the bottom?
Terry Wilkerson
Kansas
Terry
GMC 1500
upper left corner of pic.
86c10twotone
MD
Roy
They are very expensive and hard to find . Mine just clicks and the door locks randomly work haven’t figured it out yet
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Get a door lock relay from a mid 90s GM car or truck. Make sure you get the connector and several inches of the wire.
The wire colors will match up with the exception of a black wire. Since the factory relay grounds thru the mounting bracket, you will need to ground the black wire to solid metal. Problem solved.
350 w/203
I'm betting on the switch.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Since the OP asked about the relay, I assumed he knew for fact the relay was defective.
Before just replacing parts, do a little detective work. The relay is truggered by the switches, they are powered by the courtesy lamp fuse. If the courtesy lamps work, the fuse is good. Check for power on the orange wire at either switch. If you have power, next check for power on the other 2 wires (I don’t remember the colors) one wire should show power with the switch in the “lock position, the other wire will have power in the unlock position.
If that’s good, check the circuit breaker on the right side of the fuse box. I believe the power door lock relay is powered by a heavy gauge orange/black wire. If you have power there, it’s time to check the door lock relay.
VFL1982
