Door handle spacer
John Reason
Bath, NC
I'm looking for the specs on the door handle spacer that spaces out the door panel and the window regulator. LMC shows this part but it's not currently in stock. The part looks like a small cylinder shape. Probably just as easy to make one if I can find out what it's made out of and how long. These are missing on both on my K10s . If anybody has any laying around and want to part with that would be great to.
Are you talking about this piece (#33)?
If so, that part is just a piece of foam rubber. I always thought it was there just to seal up the gap around the regulator shaft and the hole in the door skin. You can easily make one out of a piece of 3/8'" foam rubber pipe insulation. It's about 2" long - max. But to be honest, I wouldn't worry about it. It should not be called a spacer because it isn't one.
John Reason
Bath, NC
The stock spacer is 1-1/2" long and about 1-3/4" o.d. Found an old one.
mick84
