Doing away with fuel tank selector valve??
jayrat24
NE Oregon
Jason
I’m working with my son on his ‘84. I seem to remember my dad teeing the lines together so it pulled from both tanks on his ‘78 we had in the farm. He’s not around to ask anymore so I was wondering if anyone has seen this done before. Thanks
The Right side of Washington
Theoretically I think it would work with no return line. Absolutely won’t work if running a return line.
Although idk about once tanks get lower on fuel and could see one sucking air and breaking the suction for fuel flow if one tank pulls easier than the other.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
xm20k
Girard, Ohio
Yes, I would highly recommend either a manual valve at some point you will suck air and lose fuel pick up teeing them together or just run one tank it's less capacity, but it won't starve itself and leave you stuck somewhere.
jayrat24
NE Oregon
Jason
Thanks for the replies. I think we will just make sure the switch is working. I hadn’t thought about the fact that it could pull unevenly.
duncan_schawalder
