- Jul 16, 2020
- Los Angeles
- Franklin
- c10
All,
As the title says, I have an 87 fuel tank, which a forum member pointed out, has baffles and is designed for fuel injection engines and in tank pumps. A standard sending unit for carb engines and mechanical fuel pumps has a float to read the fuel level, this would get down to 1/2 full then hit the baffles. So, my fuel gauge has never worked right.
I have looked around, but as far as I know, there is no sending unit made that would work for me. So my question:
-- Should I just replace the 87 tank completely, so I can have a sending unit and gauge that works finally?
-- If so, should I get a 16 or 20g tank?
Included is a pic of my fuel door location. The sending unit is at the cab/bed line, and the fuel door is currently in line with the aft end of the 16g 87 tank. It seems like a 20g would require gymnastics with the filler neck, so I am inclined to go with a 16g and get a 5g jerry can to carry in the back.
Thanks for any input,
BRetty
BRetty
