Do I need this part?? Install
84 c10 o skool
Houston, Tex
Steven
383 stroker
I'm ready to drop motor back in and redo electrical.
Just want to make sure.. this switch/vacuum port is for lockup transmission??
350runner
tx
Ceasar
Yup
marks86
Latham, NY
Mark
12v Cummins
yes Im pressure sure that's for your transmission vacuum, do you have a 700r4?
350runner
tx
Ceasar
The same switch was used for both.
firebane
Calgary, AB
Curtis
TH350 only requires vacuum off the manifold not an object such as this. The TH350C uses a different setup which uses a connector on the left side of the transmission.
OP has a TH350 so this is not required.
350runner
tx
Ceasar
I just got rid of a th350c and the lock up connector is in the same side... same vac switch I seen in the yards. Guess they could be different somewhere.
firebane
Calgary, AB
Curtis
TH350Cs are a rare breed unlike the TH350
Boone83K10
Boone, NC
Benjamin
You can drop that in an envelope and mail that switch to me..
smdepew1976
Centralia
305 for now
Boone my 1985 c10 has one that isn't in use if you'd like I'm sure we could work something out
1985 C10 305 for now 350 waiting for installation
Boone83K10
Boone, NC
Benjamin
Sounds good
Was it operational? I don't want the one from the passenger side for ESC, people get them mixed up all the time
350runner
tx
Ceasar
Yea they are less desired. My Trans builder wouldn't even take mine for free....Lol sad but true.
MadOgre
NA
NA
NA
NA
NA
I would leave it in place. You never know what time may throw at you:) Just tie the wiring up neatly under the frame at the transmission.
I am looking for the pig tail that connects to the TCC switch.
smdepew1976
Centralia
305 for now
My truck has both neither is hooked up. Im outa town with the holidays for the next couple weeks but after I get home I will snap a picture to make sure its what your wanting.
dynoh350
