Do all stock engines in a motorhome have a rv cam?
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
1983 pace arrow 454 gen 4, putting in my squarebody. So curious if it's got a rv cam, guessing so since it's out of a rv.
84-C20
Chevrolet
I'll watch this thread as I'm sure an engine builder will come along and tell us for sure, but I "think" the answer is no. I "think" that an 454 RV engine is going to be the same as any other heavy duty 454 (example 1 ton truck) in the same year. I believe the term RV cam denotes a cam other than stock that is like one step up or very mild, it would make a little more power than stock, might give you a little better MPG and will have good idle quality. However the specifics are going to vary some from camshaft manufactures.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I hope it has higher compression than '79.
Catbox
Peter
C20 Silverado Camper Special
Nope.
As mentioned earlier, it is like a step above the factory cam in most cases.
My 454 has a "RV" cam in it.
With the carb, intake, and headers upgrade mods done to the engine you can just barely hear the cam in there.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I can't speak for all but I've always understood that there are 3 stages of rv cams. I believe they were given kinda randomly depending weight and size and on what rv manufacturer was able to get there hands on. Sometimes the label on the valve cover will tell you. I had a 77 440 in an rv that said it was a class 2, 440 I was assuming it meant it had a stage 2 rv cam?
85K304SPD
Las Cruces, NM
Richard
If it came in an RV then it must be an RV cam. Just like the tires on an RV are RV tires and the seats are RV seats. Haha... But really, it is probably the same as the truck 454 on the same years. RV cams are probably a non factory upgrade, to give a little more power.
bajadiver
