DIY - Battery Cables
Catbox
Peter
C20 Silverado Camper Special
Thank you all.
I like to make the stuff I need if I can.
In all reality it does not take all that long to produce the terminal ends.
I have all the stuff sitting around the garage, so by the time I got in the car and found what I wanted locally I could have already built these.
I need to make a new set for my truck, but I will wait until I get the new battery tray and hold down for it.
Do it all at one time.
crpntr78
Missouri
Just an observation, why didn't you put shrink wrap on the two little wires as well?
Catbox
Peter
A most excellent question that I have no real answer too.
But, I think I will on the next set that I build.
Thanks for the observation.
I make my ends out of copper tubing also.What are you using for crimpers? I bought a pair of bolt cutters I was going to cut notches in the jaws as crimpers, been using a dull chisel and hammer.
Catbox
Peter
I have used a dull screwdriver and hammer.
With just enough hammer to drive an indentation and not through the copper.
I still have the first set on my VW that I made for it 15 years ago.
They fire it right up.
I'm going to cut notches in bolt cutter jaws. I'll post results
Maxwellvis
Portland Oregon
Max
Silverado Camper Special C20, 3100
Just finished building the positive cable for our truck. Gotta say, it was pretty fricken easy over all, if you can play with a torch and smash the copper tubing with a mild amount of precision, you should be able to do it.
Auburn, Washington
Nice work! Never occurred to me to make cable
lugs out of copper pipe.
Learn something new every day. Thank you for sharing.
Catbox
Peter
So easy, my kid can do it!
He put the cables on the truck this morning and they work like champs.
Now to get the other ground cables made and installed.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
agreed
Carb'ed Vortec 350
Thanks for sharing. Great write-up!
Bean_64
