Distributor Wiring
jh86
united states
Jon
1986 K10 305 700R4
Originally had ESC but dad had abandoned in 90s
I am swapping engines. New engine has HEI also.
The distributor had a combo connector into the ignition slot. Black connector runs to passenger side. White connector runs to drivers side.
My guess was that black went to esc and white is ignition.
What are these for? Do I need both? Can I leave off black if not using esc?
Thank you
IIRC, the terminals on many distributor caps are marked/ embossed with something like BAT and TACH. All you need is 12 volts ignition-switched to the BAT terminal.
jh86
united states
Jon
Thank you. Do you know why the truck originally had what seems to be 2 wires connected to BAT on distributor?
The standard HEI power connector (many aftermarket places sell replacements) has only one wire. However, if you had ESC maybe it had another powered device.
Nardulli
St Louis
C15
As far as I know all you need is 12v switched with at least a 12 g wire and the other lead is for a tach.
jh86
united states
Jon
Agree that’s all I should need. But this truck has a second wire tied into BAT and goes into factory harness. So I’m trying to figure out what the 2nd wire goes to and if I need it.
Sad Sack
Nebraska
Goober
C15
Would something like this help you?
jh86
united states
Jon
Hoping one of the very smart folks on here knows the answer and I don’t have to resort to such a laborious endeavor.
Sad Sack
Nebraska
Goober
C15
I have heard of people wiring their electric chokes to this terminal and it is not a good idea at all.
jh86
united states
Jon
It is definitely an original factory connection and was not the choke wire. Choke wire is accounted for.
I have found 2 wiring diagrams for square bodies. 1 insinuates it goes to esc other insinuates that it goes to speed switch valve. But I can’t find it in a wiring diagram specific to my truck.
Sad Sack
Nebraska
Goober
C15
Not quite certain but I thought I read that the ESC was a 4-wire connector, so I bought a by-pass connector just in case for the ESC and it is something like this:
Hope I bought the right deal though.
jw23655
