Differential Fluid advice
mavtricks71
az
mike
My 86 k10 has Dana 44 front axle....can you guys tell me what fluid it needs and does it need additives ect?
hatzie
k20
No additives in front or rear axles. Not needed up front and open rears. Limited slip additive is bad for the optional Eaton G80 lockers in the rears. Just steer clear of Limited slip additive.
GL-5 80W90 Synthetic gear oil is what I use.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
No sarcasm, but enlighten me. I have friction modifier in both my rears. I have clutch posts in each of them.
Rusty Nail
Rusty
350sbc
I used to always put the extra , additionally purchased "posi additive" in the G80 8.5" 10 bolt behind my SS. I'd dump the little bottle they would sell me at O'Reilly's but i'm not 100% convinced you can still get something like that today because today's GL5 has it already, needed or not.
Idgaf WHAT the manufacturer recommends lol. I think "posi additive" is old-tech. The SS sees only stupid SEVERE service and that made me feel better about PUNISHING it.
Btw, that 10 bolt is still alive today, 130k? miles in.
/shrug
hatzie
k20
The G80 isn't a limited slip diff it's a locker. There is a difference. http://www.fourwheeler.com/how-to/1101or-locker-vs-limited-slip-differential/
GM didn't put a Limited Slip Diff in the light trucks til at least the 1998 T800 light truck chassis... maybe the 2007 T900 light trucks. That doesn't preclude someone installing an Auburn or Eaton or other limited slip in the last 30-50 years or so but they didn't have one stock.
If you have an Eaton G80 locker or Gov Loc diff lovingly known as a Gov Bomb... Be careful of the gear juice that says "Energy Conserving" on the API seal.
This is the 1991 TSB about Limited Slip Additive and the Eaton G80 lockers.
LOCKING DIFFERENTIAL LUBRICANT (SERVICE INFORMATION) #91-4-109
SUBJECT: LOCKING DIFFERENTIAL (G80) LUBRICANT - (SERVICE INFORMATION)
VEHICLES AFFECTED: ALL LIGHT TRUCKS EQUIPPED WITH G80 REAR AXLE ALL YEARS
Some light duty trucks equipped with locking rear axles (G80) may exhibit rear axle chatter, especially when turning a corner from a stop.
This condition of alternate engagement and disengagement of clutches in differential assembly is usually caused by contaminated axle lubricant.
To correct this condition, drain and refill the rear axle with SAE 80W-90 GL5 (P/N 10950849).
The use of any additive in locking rear axles (G80) is not recommended. Rear axle additives are designed for use in limited slip differentials which are normally installed in cars. All light duty trucks equipped with RPO G80 make use of a locking differential and the use of additives will delay the engagement of the locking mechanism and may decrease axle life.
VEHICLES/COMPONENTS INVOLVED: Light duty trucks equipped with locking rear axles, RPO G80.
SERVICE PARTS INFORMATION:
Part Number Description - 10950849 Lubricant, Rear Axle (1 litre)
Parts are currently available through CANSPO.
WARRANTY INFORMATION:
As specified in Light Duty Truck Maintenance Schedules, locking rear axle fluid drain and refill is required owner maintenance at the first engine oil change. Failure to drain and refill the rear axle as specified may contribute to a later axle chatter condition. Refer to the appropriate Light Duty Truck Maintenance Schedule or service manual, section OB, for further details on change intervals.
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved.
Rusty Nail
Rusty
350sbc
Haha! Thank gawd...
Ahhh the "good old days".
'Indescretions of youth' I call them - but that stuff was all expunged :D
I wouldn't go back for nothin!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The one in my front axle is an Eaton clutch type 30 spline carrier. The one in the 12 bolt I assume is an Eaton as well. Neither are Gov- Bombs
hatzie
k20
Not everyone lights up their tires every chance they get, I guess...?
Yup. Not everyone needs a Dana 60 front axle under their truck... we aren't running 76 and later Ford F-series 1/2 & 3/4 ton pickups with that miserable Dana 44 TTB.
I have two eight lug HD Dana 44 axles. One Dana 44 closed knuckle on a 1972 F250 Ranger XLT Camper Special and one RHD HD 8 lug Dana 44 on my 1976 K20 Silverado Camper Special. Supposedly they should both be dead and gone because they are so "weak" :anitoof:
In reality I don't run 44" tires on those axles and don't do 4wd burnouts. I wouldn't run more than maybe 33" tires max. They do just fine with just under 32" 265/75R16 tires and no burnouts.
hatzie
k20
Neither of those are stock diffs either. Good that you know what's in there. After 30-50 years of service to multiple owners the only way to know positively is to pull the cover and look.
If you have a LSD then by all means put in the additive... those are an exception to the norm.
GM didn't put lockers or limited slips in the front axles of the squarebody light duty trucks and they only put the optional G80 Eaton Gov Locks in some rears.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yeah I had the rear axle apart and I put the Eaton up front. This was done to gain traction as well as slow the breakage of parts. I figured the posi will slip before breaking axles. Hopefully a win win situation. We shall see win a couple of weeks.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
So true...
There is a huge range of use/abuse one can put their trucks through.
And speaking of D60s...
They are NO stronger STOCK than a D44...! That's what I said. Until the stock stub shaft is replaced with a 35 spline (D70), it is in danger of breaking just as much as the D44. I can't figure out why GM/Dana did this... or maybe I can? When you beef the D60 with 70 stub shafts, the next weak link is the
universal off the pinion. Beef that and then the CVA into the TC is the next 'fuse'.
Lots of guys with 40+ tires don't have the torque and gears to spin them anyway. Maybe shouldn't call them 'guys' as much as 'posers'.
Hard
