Differences in a dually?
Rollin_Thunder
Oklahoma City, OK
Robert
I'm toying with an idea of making my K30 a dually. Is there any difference in a dually's 14 bolt FF rear end and my single wheel 14 bolt FF? As well what would the difference be with the Dana 60 Kingpin up front. And did the dually come with a rear sway bar?
nvrenuf
Mobile, Al.
Everything in this post pertains to pick up duallys, not cab & chassis duallys.
A 2wd dually would have a rear sway bar.
A square body dually would have a d70hd rear axle which is about 5" wider than an srw 14 bolt.
A 91-ish or newer new body style dually had a wide 14 bolt.
The dually d60 front uses different bearing hub/rotors with the stud flange further out to match the rear track width. Srw and drw hub/rotors are interchangeable on GM axles. All other parts (locking hubs, bearings, calipers, etc) are the same.
John81287
Mchenry,IL
V20
I have an 85 c30 dually rear axle if you're interested!
Rollin_Thunder
Oklahoma City, OK
Robert
I might be John. I guess it would depend on shipping. And thanks for the info John. I've been toying with making mine a dually as of late because I want to make it a dedicated tower/hauler truck.
John81287
Mchenry,IL
V20
I've got one sitting out back on my 85 parts truck. Let me know so I can get it pulled. I'll let you have it pretty cheap. Make me an offer.
marks86
Latham, NY
Mark
12v Cummins
Cab and chassis, and motor homes had 14 bolt DRW instead of D70
JOD26
