Death wobble, or bad wheel balance?
Dano500
Houston, TX
@Grit dog I haven’t finished putting it on yet. Maybe I’m tired and not thinking straight.
The box info card stated the box is already centered (about 1.6, or 1.7 turns each side). So, I line up the flat spot on spline shaft to flat spot on steering shaft, but in order to do that, I have to rotate wheel almost 180 deg. Doesn’t the steering wheel only install one way? What am I forgetting?
Dano500
Houston, TX
Replaced steering box, shocks, stabilizer and 4” springs. Gonna take it for a spin. Hope death wobble is gone.
mattsk8
Michigan
@Dano500 did your wobble get any better? You mentioned all those parts replaced but never mentioned replacing your bad ball joint. If you haven't I'm surprised, a loose or bad ball joint isn't a minor thing and can cause basically everything you've described as a problem here. I'd have done that before replacing any of those other parts.
Dano500
Houston, TX
It rides much better now- no wobble at all. Ultimately, I think it was bad balancing of the new tires. I went back to D T and asked them to rebalance them because of what was happening and now it drives and rides great. Well, except a little steering slop. I’m going to do the jeep steering shaft mod next.
The Right side of Washington
But…I’ve seen it up for sale.
Juggernaut
Illinois
Greg
That’s right, it is for sale. I got it specifically to pull my fifth wheel, and now that I know it won’t….
A K20 that won't pull a 5th wheel? How big a 5th wheel you got? It should pull it easily
Dano500
Houston, TX
It’s 19k lbs loaded and 15.7k empty. I bought this 84’ k20 C6P in hopes of rebuilding it and putting in a Cadillac 500 with a 4l80 to pull it.
hauto85
