tetind
- Jun 16, 2026
- bama
- tom
- k3500
truck- Frankensteined 79 k3500 dually. no bom on rear axle housing...Ive cleaned to the white meat on both tubes 360 degrees. 3.73 ratio 35 spline. 70HD in fwd web casting, C37453 casting opposite side, B149..maybe 140 at bottom, have no idea if this is relevant for a data miner but there it is......the carrier is a 4 pinion 2 piece carrier standard. 4 spiders stacked on a cross shaft that is open in the middle. side gears and spiders only have thrust washers behind them(not a power lok stack). *****can i replace my side gears with the side gears available on the market for the 1 piece carrier assy?**** can not find any interchange info much less a PN.
only place i can find my 4 pinion 2-piece carrier is in an old dana pdf on billavista.com file x510-9. If standard 1 piece carrier 70hd side gears wont work, what are my options outside of axle swap due to lack of part support for this config?
Let me go ahead and thank ANY one that responds to this with insight. My hat is tipped to your knowledge and obvious years of experience in dana parts identification and interpretation.
