cs 130 alt upgrade
350runner
tx
Ceasar
There's a way to do it without bud :). You can try running without :) or just wire up a lil bulb and run it.
MadOgre
NA
NA
NA
NA
NA
Has it been mentioned already that the CS130 and 144 are not direct bolt ins ?? They don't fit the stock SB brackets
Moderator Administrator
@NOPHO84K30 All that great work you've done with the electrical upgrade can up in flames in no time if you don't get rid of that glass fuel filter. I've seen and heard of it to many times. They are cool and beneficial with the sight glass, but with engine vibrations, they are well known to come loose then you're spilling and pumping gas all over your engine at 4-7 lbs of pressure. Then all it takes if slightly defective plug wire boot or loose connection on any wire with a small arc and now you're truck is up in flames. The cheap ass disposable frosted white plastic ones are much safer.
Now, Back to regularly scheduled programming.
350runner
tx
Ceasar
So with either factory or aftermarket intake it will be necessary to mod the intake bolt hole. I've found it necessary when using an aftermarket intake to mod The intake hole regardless if your using the stock alternator or not. You may end up having to cut the bolt hole open to mount the alternator bracket to the intake and use a couple flat washers.
MadOgre
NA
NA
NA
NA
NA
What do you mean cut open ?
350runner
tx
Ceasar
Make it slotted.
MadOgre
NA
NA
NA
NA
NA
Oh the bracket?
350runner
tx
Ceasar
Yes the intake bolt hole on the bracket
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
So what is the difference in the cs130 alternator and the cs144 alternator? Which is better to have and are they both wired up the same way, such as installing them.
MadOgre
NA
NA
NA
NA
NA
The 144 is supposed to be more reliable because of beefier internal components as well the 144 cranks out 20+ more amps then the 130
72chevy2door
Florida
Jeff
So the CS-144 is better over all?
350runner
tx
Ceasar
72chevy2door
Florida
Jeff
Sweet. I'm looking into getting a new alternator as the bearings are squeeking in mine. How hard is it to wire up in a 88 suburban?
350runner
tx
Ceasar
Pretty simple actually.
72chevy2door
Florida
Jeff
So from what I read online is the CS-130 alt and CS-144 use the same harness adapter. Is that true?
crowe-t
