Crooked bed?
WillSquared
Arkansas
Will
Alright guys, this has irked me for a while now and since Ive added the new bumper Im determined to figure it out and correct it. Ever since I bought the truck the back end has been unlevel or just crooked looking. As you can see in the pic below, the bumper looks bent but it is brand new and straight. The bed is higher on the passenger rear corner by about 1/2" or more. Then the tailgate seems to be sagging over on the drivers side and the triim doesnt line up there which adds to the crooked look of the whole back end.
So having all that said, whats my solution here to get everything lined up and looking nice? I figured maybe some shims over on the drivers side to bring the body up a bit? Maybe some new hinges on the tailgate?
The strange part is that it was worse and I already removed some shims from the passenger side. The tailgate seems to be sitting even on the top but the trim is off on the bottom. Its all just driving me crazy. Any help is appreciated.
Skweegle89
Oklahoma
I think you need new body mounts
yevgenievich
Place
Name
Year
Model
Size
I agree, get new body mounts first and then see if it still needs adjustment
CSFJ
there are no body mounts under the bed though. My older brother tried chasing this problem when he bought his truck new back in '83. I seem to recall he finally found out that it was built like that. someone screwed up a blueprint somewhere in the design stage and no one noticed until they started rolling off the line.
CSFJ
the only thing I can think to do would be to adjust the bumper to the bed for level.
yevgenievich
Place
Name
Year
Model
Size
I was just looking at a set of body mounts near a rear bumper, but now realized it was on a suburban. If frame is not twisted, then I think there might some play in the bumper brackets where they bolt to the frame for adjustment.
WillSquared
Arkansas
Will
The old bumper was off too. So twisted frame? Great
Sent from my iPad using Tapatalk
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Your leaf springs could be sagging on the drivers side. I'm pretty positive that's what's wrong with my 79, these squares have a lot of box roll when going over uneven ground so a sagging spring could cause that box roll just sitting there. That's my theory haha
WillSquared
Arkansas
Will
I do think my leaf springs are shot. But I don't get how that could effect how the bumper aligns with the body since they all bolt to the frame?
CSFJ
If you can loosen all the bumper brackets, you may be able to shift it enough to get it closer to aligning with the box.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
How does the box line up to the cab? The trim is really weird and does add to make it look crooked, the tailgate looks like it lines up somewhat decent.
Boonie
El Dorado, KS
Brent
I may just be seeing things, hard to tell, but it looks to me like the trim itself is crooked/bent/drooping on the drivers side of the tailgate. Just what I think I see, idk.
WillSquared
Arkansas
Will
The bed lines up with the cab pretty decent. It's a little over to the passenger side up at the cab but not horrible. The lines themselves are straight.
And yeah, the trim does look crooked. The top of the tailgate is pretty even, but the trim doesn't line up over on the drivers side. Also, if you look closely the red striping is off over on the passenger side, but the trim itself lines up. It's all very strange.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I would start with tailgate hardware and try to do something about that trim, I think the trim is making it look way worse than it is, then see if you can adjust the bumper after that if it needs it. That's the route I would go then your tailgate will open and close great too!
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
My bed looks crooked also. My plan, if I ever get time, is to park the truck on flat, level concrete. Then I'm going to start measuring the frame to ground on both sides, then bed to ground on both sides and bumper to the ground on both sides. With all those measurements I'll know if it starts with the frame/springs. It the frame is level then it is time to add shims to the bed or try to adjust the bumper if possible.
Or probably just live with it. It is a nearly 30 year old truck that was worked hard in its life.
