Converting burb rear ac housing
87dieselburb
Massachuaetts
V1500
Ok well here's the deal I have a 89 burb im using primarily as a plow truck it doesn't have rear defrost and it becomes a bitch plowing and not being able to see out the back and there is no guts in the rear ac housing so I was woundering if it's posible to splice into the heater hoses and plumb it to the rear and put a blower in that housing so it puts hot air directly on the back windows someone please tell me if this is at all possible or if I'm just dreaming of the impossible
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
It could be possible with some type of heater grid or something, but I don't think you'll be able to get coolant to flow all the way to the back and to the front again, at least not very easily of course.
yevgenievich
Place
Name
Year
Model
Size
It can be set up similar to factory. Replace ac hoses with coolant. Put heater core inside housing with a fan blowing towards the back doors.
Factory heater was on the floor, this would just move everything to the top
Moderator
This was brought up before, the issue is coolant level being higher than the radiator cap. Even newer vehicles with heater outlets up high in the rear, it's just ductwork with the heater core mounted down low near the floor.
Georgeb
Wisconsin
George
K10 Burb Z71
Why not something like this mounted so it blows on the back windows. Less trouble than messing around with coolant....
yevgenievich
Place
Name
Year
Model
Size
Electric does sound like a way to go. I did not think about the radiator cap, but it is possible to mount heater core on the floor part of AC cover and use blower fan
87dieselburb
Massachuaetts
V1500
doesn't it use height pressure to move coolant thought the lines and heater core?
87dieselburb
Massachuaetts
V1500
Doesnt it use height pressure to move coolant thought the lines and heater core?
yevgenievich
Place
Name
Year
Model
Size
I was thinking of factory heater set up at the floor level blowing through the AC cover ducting to the top. But electric would be easier and faster to set up regardless. Plus, the AC blower wires and control switch can be used to turn it on.
Georgeb
Wisconsin
George
K10 Burb Z71
Provided they will handle the amperage. That 250 watt heater will pull over 20 amps at 12 VDC.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Relay, but then you still have to run another set of power lines back there.
Georgeb
Wisconsin
George
K10 Burb Z71
And that is still easier than coolant hoses.
yevgenievich
Place
Name
Year
Model
Size
The factory blower wire is right around 12awg.
VFL1982
