Cold Start
MrMarty51
Eastern Montana
Martin
Yep, being he's already got the manual choke carb, that's exactly what I'd do.
He will find it much simpler to install, no adjustment BS, and really, it's very easy to operate and much much more dependable than Auto Choke.
Is trhat one of them that it is advisable to mash the footfeed all the way to the floor "BEFORE" giving the choke cable a pull ??????:hat:
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I don't think a single one of my chokes work correct on any of my squares. pump them a couple of times and all them seem to start fairly quick, and idle right off. unless temp is below 20* it's never a problem here. Funny tho no one else can ever get them to start here since most of my help is used to fuel injection.
woodsrider250
Fredneck, MD
350-Qjet
My old hot air choke doesn't work perfect, but it works fine. Two pumps, light her up, idles a touch rough for a few seconds, then fast n smooth til you kick it down.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Nother thing that make these a bitch to drive when cold is, the exhaust crossover passage being blocked in the manifold.
Moderator Administrator
YEP, I agree. Those chokes are a bitch and a PITA. I'd rather just do the manual chole pull. Eihter that, convert to TBI, TPI or Sequential Vortec Injection.
I'd like to anyway on my 4x4's to be Injected, then you can also add an electric start to them too.
Driver4r
Nebraska
Trevor
k10,c20
Mines the same setup
