Coil & cap upgrade
Geektrucker
Maine
Joe
Scottsdale Suburban C10
350, Vortec Heads, Hi-rise intake, long tube headers, BIG bump stick
So my 81 250 Inline 6 has an older round external type coil.. I'd like to replace it / upgrade to an in-cap coil. Does anyone know of anything special I need to do other than replace cap & rotor, buy the coil, and wire in the power feed? :shrug:
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I'm sure they make HEI for I-6's. As far as I recall way back many moons ago, when I swapped in an HEI to a points trucks, it was exactly what you mentioned. Just need the new distributor, coil, and etc., wire in the power and get new spark plugs or just re-gap them and wires. New plugs would be good so you're getting full spark unless you've already switched them out, then just re-gap them.
I'll be doing this very swap, but to a v-8 truck soon. For mine it's going to be new cap, rotor, coil and plug wires. I already have the new plugs. I like the HEI setup because it has the tach terminal built-in the cap and coil.
MadOgre
NA
NA
NA
NA
NA
A 4.3 V6 will use the distributor you want with 6 reluctors and then you just designate the cap terminals according to your firing order.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Sounds like a cool upgrade.
Geektrucker
Maine
Joe
Do I need to replace the entire distributor, or just cap, rotor button, & coil?
Sent from my DashPad via SmokeSignals
Geektrucker
Maine
Joe
The whole dizzy from a 4.3 will fit into the Inline 6? Or just cap, rotor etc.?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
It's the whole thing. For a v-8 anyhow, the cap is bigger to house the coil in the cap. Probably the same for an I-6.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
My guess is the whole dizzy needs to be acquired.
MadOgre
NA
NA
NA
NA
NA
I actually do not know if a V6 dizzy will fit. Only one way to find out though. Take some measurements of your I6 dizzy and then go to the junk yard and see, if it looks like it will interchange then take one home to see if it will.
