Clutch linkages and springs?
Baxter Beutler
nebraska
baxter
Mid frame off restoration on a 77 Chevy k10
350 sbc 4 speed trans and that good transfer case, (don’t know the technical name )
Does anyone have any good knowledge on the way that the springs for the clutch bell crank go.
I’d like to tackle this while i have no cab in the way. Clutch was also sticky when it drove so I wasn’t sure if it was something up in the pedal or in the bell crank area. I put a cheater bar on the clutch fork and nothing binds or feel strange there. Thanks in advance if you have any photos or information of how it should go.
hoagster
California
K10, 1500
5.3l
I know your a ways off from getting it all back together, but the clutch/brake pedal assembly has some bushings in it and the clutch linkage bar probably has some wear so those are area's to look at also. Here a a few pictures of my setup that I'm still perfecting and waiting on cab install also.
The long spring connects to a hole in the frame just in front of the shock mount.
Dennis Blom
