clunking axle
WilliamBill
ohio
Bill
does anybody on here have a good fix for the GM 10 bolt axles clunking against the pin inside the differential, beside just turning the radio up!
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I'm guessing you're talking about backlash? Rear differential? Going from park to drive or reverse with auto transmission? Idle too high?
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Are You sure it's not a u joint?
SquareRoot
Replace with a 14 ff. Problem solved.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
If you are referring to lateral axle play related to them being a c clip axle, not that I know of. Half ton trucks still make that noise to this day…
WilliamBill
ohio
Bill
i am talking about the c clip axle clunk, I guess it is what it is. clunks when i rock the truck sideways while stopped. I probably should check the u joints as well, thanks
Camar068
Kentucky
10 yrs Air Force
what do you mean rock the truck sideways? I need to see if mine does that.
WilliamBill
ohio
Bill
when it's parked , grab the bedside and push it back and forth, click, click,end of axle shaft knocks against axle shaft retainer pin in rear end, maybe 1/8" play, sounds worse than it is
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
What I don't understand is how the axle slides in the outer wheel bearing?? isn't that a pressed fit?
scrap--metal
MN
Calvin
'85, '81
K10, K20
He's talking about the rear axle. Outer wheel bearing is pressed into the axle tube, but the axle itself slides out freely once the c-clips are removed.
I've owned several GM's with 10 bolts, but have never noticed the clicking you described.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Yes this is true I have removed 3-4 of theses rear axles I wonder now how the bearing last when they aren't a presed fit?? I have heard that clunked before but was 40 years ago
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
My 2019 z71 1500 did the same thing. Noticed it if I didn’t approach speed bumps square because the truck would jiggle.
I could replicate the noise/click doing exactly what William has described.
Had a thread about it here a couple years ago, in fact. I believe Rusty tried to console me by comparing it to an AK…
squaredeal91
Greg bush
1991 SB
Tried to console by Comparing to an AK!! Lol that hit me funny
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
They are rattly sons-of-babushkas, but they do run.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Old c clip axles do that.
sallyjeank10
