Cleaning the garage!!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Everything I’m posting here (unless specified) was installed in one of my vehicles so I know with absolute certainty they work and function as intended. If you see something your interested in, let’s talk. I’m in central Indiana 46902
Autometer Ultra lite 2 1/16 electric fuel pressure gauge. 0-15 psi. With the sending unit and harness. $75
Holley Sniper EFI. Never used, never installed. Unopened instructions and wiring harness $800
Autometer Ultra Lite 2 2 1/16 trans temp gauge. I installed this and powered it up ONCE before I noticed the backlighting and gauge needle didn’t match the other gauges in the car. . Includes a new sending unit and the harness. $100
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
QBuff02
Central IL
Quincy
Does the Sniper have the pump and components too? Or just the base unit?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
It’s just the EFI and related parts. The fuel pump isn’t included with the basic kit.
So what color backlighting is the trans temp and fuel pressure gauges?
Camar068
10 yrs Air Force
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
the trans temp gauge still has a white background lighting, it’s just a LED white. It’s not noticeable, until you have it lined up with a bunch of other lamps with regular incandescent bulbs.
QBuff02
Central IL
Quincy
How's the Electric fuel pressure gauge work? I've only dealt with mechanical ones with the isolator that goes on the firewall so i'm curious.. I'm assuming it just has a sensor that goes in line..
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Exactly like a mechanical, except your running a small harness instead of a fuel line. The sending unit has 1/8 pipe threads, and is about the same overall size as a factory sending unit for a warning light.
Other than the sensor harness, it takes a power, ground, and connections for the backlighting.
jingle1
