Changing the stock manual to a car style four speed
794spdcustom
Alberta Canada
Brad
Custom Big 10
Good Day folks; I have a 79 big ten custom , 350 4 speed and would like to know if anyone has replaced the original 4 speed to something like a muncie or Borg warner, saginaw car style stick? What all needs to be addressed in a swap such as this?
Thanks
Brad
The SM465 uses a large bearing retainer with a matching larger register in the bellhousing. I'm not sure if there is a proper spacer available or if you are stuck swapping the bellhousing too.
Shorty81
Baby Boomer
North West ohio
Darren
If you have the sm465 now you have the best manual transmission out there. IMO
Rickf
Grafton NH
1974, 1954 & a 1937
A car style bell housing for a muncie might not fit around a 12" flywheel/clutch that should be in front of the sm465.
:cheers:
Wouldnt the NV4500 be nicer to have because of the extra gear or is that an overall quality/simplicity/availability argument?
sallyjeank10
