Carpet
ben82k10
ohio
Ben
6 cyl
I plan on adding carpet to my 82 k10 manual. Any places you recommend or stay away from? Also do I need both sound deadening and heat shield or is one ok?
ali_c20
Austria
Alexander
C20, K5
ben82k10
ohio
Ben
6 cyl
Has anyone bought from oc auto carpets? That’s another place I was told about. Them and lmc. I just know how well the molded carpets fit. I’ve heard/seen acc mentioned a lot.
Bloodhound1981
Law Enforcement
MA
Rusty
C-10
Yes I got mine through OC auto carpets. I got it with the mass backing. Very happy with it. I also put down Kilmat sound deadener and Dynaliner thermal barrier. I also learned a great way to make the holes in the carpet for seat frame bolts, seat belt bolts etc. After the carpet is laid down, I tool an awl, heated it up with a torch, and stuck it through the holes from underneath. Then on the top side, I took an old socket of the size hole I wanted to make in the carpet, heated that up with a torch, and pushed it over the awl, burning a perfect hole where it needs to be. Pics from the install...
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Another vote for ACC…
I couldn’t find a picture of the tool I made for the carpet holes but, I just sharpened the edge of a piece of pipe. I backed it up with a scrap of 2x4 and smacked it with a hammer. Used an awl to mark the center pulled it out right before punching each of the holes.
I had made a few different sizes of sharpened pipe that I used to punch holes in the killmat but only needed one for the carpet holes.
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
I went with the black rubber mat
Leaning that way towards Lisa’s lowrider. Gravel driveway, live on a hobby farm, sw TN weather is strange. Can be in the 70s during the day, snowing at night from November to March… Currently doing sound/heat barriers in the cab.
San Diego, CA
Jeff
Suburban
I am doing an ACC carpet from Rockauto in my 85 burb right now. Spend the money on the mass backing, I went the cheaper route without mass backing and it makes the install much more difficult. To help with any of the pre-formed sections that need more forming go get some free sandbags and drop them on the carpet and let them sit overnight or longer. That helped the carpet really suck down into every nock and cranny. Ill echo everyone else on the hole punching, I used a screwdriver heated up and punched the initial hole from the bottom. From the top side I had a 1/2" dia metal tube that I would heat up and use to burn the holes that looked just like factory. Last piece of advice is to start poking the holes in the center of the cab first and bolt those items down first and then work your way out.
tj43
Little Rock
TJ
V1500
Would you mind posting pics of your process? I plan to do my burb at some point in the not so distant future, and pics of ACC carpet installs in suburbans are few/far between.
jw23655
