carb suggestions for a 350
r.booser
Knoxville
Ron
Buying a new carb for my stock 350. Looking for suggestions, pros an cons and any other advise you guys have. From what I know motor is stock besides intake. Going in my c20
78bigblock
North Carolina
Adam
I'd go with a Edelbrock 650 w/ electric choke.
Moats31
Linesville, pa
C10 and k10
I run an edelbrock 600 with electric choke!
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
Driver4r
Nebraska
Trevor
k10,c20
Stay away from edie's........ For Gas milage, run a Q-jet, BEST CARB DESIGN EVER. If for sheer power, go with Holley 650 Vac Secondaries.
Driver4r
Nebraska
Trevor
k10,c20
They are scrap weight and pains in the ass. :)
They are easy to find cause noone wants them.
Everyone i know hates them, now they all run Holleys.
The only thing edlebrock makes thats good is Heads,Intakes,And valve covers/air cleaners(not the triangle foam ones)
Good Ole Holley Vs. Eddie :)
bobkyle2
Illinois
Kyle
K5 Blazer
If you are wanting to buy a new one.... Get aQuadrajet.... Badass carb for a daily truck.
r.booser
Knoxville
Ron
Everyone I have talked to hate quadrajet and it is about 50/50 with edelbrock and holley.
Stroked
Beloit, Kansas
Jared
I've had 3 Edelbrocks and hated every one of them. They're easy enough to mess with and get a truck to run, but they're almost impossible to tune correctly.
For a daily driver, I would go with a quadrajet if you can find a good one. The only reason they have a bad rap is because they're all 30+ years old and people don't rebuild them correctly.
Otherwise, get a Holley or maybe Summit Racings carb. That's what I'm going to order soon.
Boone83K10
Boone, NC
Benjamin
I will be buying this soon.... triple venturi, goggle valve, butterfly flaps, 200/700r4 geometry built in, looks badass. A friend put this on his monte carlo and it was amazing how much better it runs and better MPG & HP.
http://www.demoncarbs.com/1901.asp
r.booser
Knoxville
Ron
if I went with Holley would I have to buy an adaptor plate since I have a Edelbrock intake?
Driver4r
Nebraska
Trevor
k10,c20
If you want all go and no stop, get a predetor. Its either fully open, or closed, theres no middle :).
And yea, q-jets are the best carb when you know how to work on them,..
Stroked
Beloit, Kansas
Jared
Nope. Edelbrock and Holley use the same "square bore" flange.
Boone83K10
Boone, NC
Benjamin
no, if the intake is square bore then you need a square bore carb. If the intake is a spread bore then you need a spread bore carb.
Swims350
Logan WV
none
I run edelbrocks all the time, never any problems, simple and cheap to rebuild anyone can do it. I'd say why not go with a 500 cfm edelbrock or just 600? I see no need in going bigger, we run a 600 with man. choke on a mild cam 2.02 head 350 on the street just daily driver.
Dennis Blom
